Hello
It seems that have an elektrical problem. Maybe someone can help or give hints:
I own a Renault Megane I 1.16 16V Break (Year 2000). I have a Tablet-PC (Android) which I use for navigation. As internal speakers of the tablet are bad, I connected some external speakers to the tablet (via audiocable). the external speakers are getting power over USB-cabel connected to the lighter-plug with an adapter. Tablet is also connected via USB-adapter to the lighter-plug (for loading battery). So far everything works fine, but if the USB-cabel for loading the tablets battery is plugged in, I have noise on the external speakers and in a certain timeloop I can also hear a CLICK in the external speakers. As soon as I unplug the loading USB-cable the noise disappears and also the clicking. I tried different USB-adapters and also other external boxes and different USB-cables and audiocables. always the same result.
If I connect a power-inverter to a second lighter-plug which converts 12V DC to 220V AC and there I plugin a 220V AC/DC-Converter with USB-output where I take the power to the external boxes, no noise and clicking. I also tried to connect a second lighter-Plug with USB-Port to the cabin-light-power and tried to connect power for the speakers there - same issue.
Do I have an elektrical problem in my Renault, or could the problem be in the tablet? Otherwise - why is it working with the power-inverter in between?
By the way: It also works perfect with no noise and clicking, if I take the power for the speakers from an AC/DC-Adapter plugged in outside the car from the 220V in my garage.
Maybe someone can explain me the problem, or has a solution?
The problem exists if i only turn on ignition (12V) or if engine is running (14.4V)
Greetings
Mitch
Greetings
Mitch
