Guy's getting a grinding noise when on uneven road types ok on smooth motorways but on b roads can hear noise/grinding from front drivers side wheel
Any ideas
only thing I can think of is wheel bearing, but strange you don't hear it on smooth road surfaces
Is the noise intermitant? Only reason I ask is because my last Laguna suffered the same problem......only it turned out to be that the engine protection panel was hanging off slightly on one side and was grinding on the road whenever the camber changed. I know it probably isn't the problem, but it's always worth looking yourself before you end up spending a fortune on something that doesn't need to be done.:)
