can anybody help my car clio 1.4 got no spark after been in the garage for 18 months battery fine & fully charged but theres no spark from coil got fuel upto carb but dont seem to be spraying down carb are these linkd or have i got two probs to deal wiv thanks??????????
If your car has the renix ignition system they are known to get corrosion on the coils contact pins, the coil should be held onto the ignition amp unit with 2 or 4 torx screws, if you take these out the coil will then pull off, check the contacts on the coil and amp for corrosion. If all seems well there then it may be a dirty tdc sensor.
