1 - 20 of 26 Posts
So I recently got a check emmisions warning light come up on the dashboard of my 2012 Renault master. To figure out what was causing it, I bought an OBD2 scanner. After trying to connect with the van it is saying "link error". Any idea what could be causing that? The male and female ports don't seem to be connecting perfectly, but if I position it correctly, the scanner stays on and can run through the protocols but just always returns "link error". Any help would be much appreciated.
Silly question but do you have the engine running? I found with the Clio that it wasn't connecting until I pressed the "start" button to start the engine, (even if it won't start).
Discussion Starter · #3 ·
Following the instructions, I just have the ignition on but not the engine running...
Here's hoping
Can you check your interface/scanner on another car , just to be sure it works first
Two fuses on your master covering Diagnostic socket
Both Number 5 Fuse
One of the fuses is in the internal fuse box.
This below
As you look at the fuse box 4 columns of fuses.
2nd row up, in the 4th column ( Should be a 7.5 fuse )
Check this one
One in the under bonnet Fuse box
As you look at the fusebox, one of the corners has been cut away
( Looks like a triangle is missing off the corner )
Take this corner missing as bottom, Follow the side up
Column of 3 fuses, or spaces for 3 fuses 2nd fuse up again 7.5 amp
Check both of these.
Discussion Starter · #8 ·
Here's hoping
Both Number 5 Fuse
This below
Check this one
I have checked all those fuses and they are all fine. I wonder if it has something to do with the connection between the male and female ports between the scanner and the car. I have to fiddle around to get the scanner to stay powered, but if I find the right angle then it stays powered and is able to go through the initial protocols. I have tried trying to take out the female port on the van but it is pretty firmly wedged in the metal casing. Do you think this connection could be causing the issue? Thanks for your help!
192348
Small screwdriver, and press hard on that tab marked orange
( You have checked your scanner works on another car.)
Discussion Starter · #10 ·
Managed to get it out. It seems that it was the loose connection that was causing the problem and it now works fine. I have now got the codes I need. There were 5 codes in total.
P2425 P2425 Exhaust Gas Recirculation Cooling Valve Control Circuit/Open
P2457 P2457 Exhaust Gas Recirculation Cooling System Performance
P1457 P1457 Code – What Does It Mean & How To Fix It - OBD2PROS
P2456 P. P1456 P.
The last two codes are the same as the previous ones with a P at the end.
Do you think these codes highlight something I could fix myself?
Need size of your engine
Yours got 1 of these fitted
Would be checking if this is still working
But start at the EGR first, make sure the metal plate inside the EGR is still there
Discussion Starter · #14 ·
So I looked at some troubleshooting for that code and one of the first things it says to do is to look at engine coolant levels. Had a look and the engine coolant is basically empty and well below the minimum threshold. Would this have done much damage? Do you think it implies a leak somewhere? I had an MOT just over a month ago, would have assumed this would be something they would check.
192405
192406
Can only say Top up
Then ( If undershield is fitted, remove it ) go give it a good run
Put a piece of cardboard under the engine and see if any water drops down
Check inside Cab for water, unlikely as this normally means you are forever cleaning steam from the screen.
But thought I would mention it just in case
Discussion Starter · #16 ·
Can only say Top up
Thanks for your help. Would I need to flush the system out before topping up? Not sure what type of coolant was in there before, the handbook doesn't say what type to use.
Just use water at this point, you need to find the leak first. if no signs of a leak, then empty system and fill with antifreeze.
Any motor factor will tell you correct antifreeze for your car
Its not cheap, and if its leaking, more money going down the drain
No pun intended LOL
Discussion Starter · #18 ·
No pun intended LOL
Well now I know for sure there is a leak. As soon as I put water into the engine coolant chamber it started leaking quite a lot. I took a couple of videos but cannot seem to upload them here. The water is coming out of the radiator. I caught it in a picture. Tried to trace it back from the radiator but couldn't see where the leak originated from. When I first started putting water in the engine coolant chamber it wasn't leaking super quick but now it has stopped and the water is just below the "max" line.
No pun intended LOL
Well now I know for sure there is a leak. As soon as I put water into the engine coolant chamber it started leaking quite a lot. I took a couple of videos but cannot seem to upload them here. The water is coming out of the radiator. I caught it in a picture. Tried to trace it back from the radiator but couldn't see where the leak originated from. When I first started putting water in the engine coolant chamber it was leaking super quick but now it has stopped and the water is just below the "max" line. Any ideas what's going on?
192416
192417
192418
Front end off now then
Then you can get at radiator
Looking promising
AGAIN dont put anti freeze in even when you have sussed Rad
Fill with water
Run it and make sure nothing else has gone t1ts up
Discussion Starter · #20 ·
Looking promising
Fill with water
Can see the part in the radiator which is leaking. Looks like a nail or something has created a bit of a gap. How to fix this? Would leak sealant do the job? Seems like I am getting somewhere now!
192419
1 - 20 of 26 Posts
