Hi All,
So after much research I was convinced my Megane was OBDII compliant...
So I went ahead and bought an ELM327 v1.4 Scanner of fleebay and plugged it in. Great! It seems to work. Loaded up the software and it can only get 2 readings?! Fuel 1 Open/Closed state and Battery voltage. Did some more digging in the software and it also seems to be able to read DTC's, but as expected reports nothing wrong.
How accurate is this? Is it worth me keeping my scanner?
Kind regards.
Edit: One of the apps i used reported a Lighting ECU, what's this?
Kind regards.
