Can anyone tell me which is the best oil filter remover to use.
As the pictures show you, I have a chain oilfilter remover and a strap and socket one.
There is not enought room to use the change type and the other type of remover, the strap started to break causing some damage to the oil filter casing which I could not budge.
After changeing the engine oil, gearbox oil , air filter and pollen filter, only to find that I can't remove that blasted oil filter, It would be a pity to
have to go to a garage or renault just to get the oil filter changed.
The third picture is of the oil filter in my clio dieasel.
