1 - 10 of 10 Posts
Hi all,
i've recently found i have a leak at the passenger side front wheel. Could this have anything to do with the power steering system?? I find that i've to put power steering fluid in every 3 or so weeks. Could it just be that or something more serious??
Ta in advance
Conor
Yeh as Chris says t sounds like a power-steering leak. I suggest you get it sorted ASAP - at the moment it may be repairable but if you end up needing a new steering rack it can be very costly indeed.:)
Discussion Starter #10
Cheers,
i'll give it a go later on when i get home from work.
Thanks again for all the help guys.
I'll let you all know how i progress!!!
1 - 10 of 10 Posts
