Can anybody help me please, I've a 52 plate kangoo van 1.5 diesel K9K 700 engine. I started spewing out oil from the expansion tank, So I've had it to bits, cleaned all the pipes out and rad etc, replaced the headgasket. Fired her back up and she ran a treat for an hour of so on tick over then the oil started to appear in the expansion tank again, when I open the bleed nipples its a thick gunge coming out the it seems to clear and water runs though, however if I leave the cap on expansion tank and the bleed nipples closed after a while the expansion tank starts to rise. I had a look at the oil cooler when I had it stript down and couldn't really work out if it was ok or not, conected a hose to it and blocked of the other end to see if water made its way across and it all seemed fine.
Can anyone help me as its now doing my head in lol.
Thanks in advance for any help
Geoff
Geoff
