Looking for some advice. Recently my timing belt was changed & the alternator + belt two days later. I have now noticed an oil leak on my driveway. Any ideas or potentially could the garage have caused a problem. No oil leak prior to the work being carried out. Megane 04 Plate, 1.5 dCi
Without knowing the source of the oil leak it would be impossible to say if the garage work caused the problem.
Can you determine if the oil is engine oil or gearbox oil.:)
