with a filter change at the same time then it should be 4.8 litres, however i find this hard to believe
i just did mine on saturday and i used all of the 5 litre jug however i lost quite a bit (maybe 0.2 - 0.3 litres) due to not noticing that it was spilling out of my homemade funnel :rofl:
so i used around 0.3l from a 1litre thingy
safe bet would be to pour in just under the 5litres and double check with the onboard puter (making sure the car is on a flat surface), stick the keycard in and it should say oil ok, then click once on the stalk and it will show a number of zero's indicating how much oil is in the sump. You want between 5 and 6 zeros :d
