Does anyone know if a diesel injector leak back test works on the old indirect injection models. There are plenty of YouTube videos of common rail, but that's it. I'm hoping the same principal applies, after all the diesel returns and the injectors do their thing.
give us clue, what engine do you refer to, lots of manufacturers used different indirect systems.
Al
if each have an individual spill pipe yes. if all injectors run through a metal spill pipe (that you cannot isolate each injector ) then no
Hello to you all, the motor in question is 2003 Kangoo 1.9 D65. It's becoming harder to start, so after seeing this test as a next step I thought to give it a go. I have removed all the glow plugs and tested them.
