Hi, myself and 2 garages are struggling to find what the issue is for my Renault scenic 2010 diesel auto.
driving along the car will randomly throw itself into 2nd gear and come up on dash as check auto gearbox. I have to pull over engine off and take the key out, it seems to reset the gearbox issue.
Driving along I’m also getting many other warnings saying,
check ESP
Check anti pollution
No hill start assist
if anyone has had the same issue or come across something like this?
thanks
Captur 2017 1.5DCi EDC
I assume this is an EDC gearbox. First thing I would check is when the car battery was last replaced. A bad battery is often the cause of spurious electronic faults. Next, if it is an EDC box, it will need to go to someone (probably your Renault dealer) who has the equipment to test the box. There will be fault codes stored that need to be read. My last car had the same problem and they solved it with a gearbox software update.
