Hello all,
my wife had to abandon her scenic the other day due to it overheating - she switched it off when the red light on the dash came on!
Anyway, it is a 1.6. I have had a look at it and am hopeful the head gasket is still OK. When I start it and let it start to get warm (hot) two things I have noticed - the top hose from the radiator does not get hot (or hard) and the cooling fan never seems to cut in?
So, do these things have a flow switch to activate the cooling fan, would a knackered thermostat cause these problems? Where and how can I short across teh cooling fan to check it works? (the fuses for it are fine).
I have pulled the top hose off and flushed the radiator and it appears water flows round the rad and system, so I don't think it is a blocked rad.
Cheers all.
DaveJ
Cheers all.
DaveJ
