update for you all, i called my local garage and they didnt have a clue.called severndale parts distributors hadnt heard of it and even renault in stourbridge said whats a pcv so im beginning to wonder as no-one on here knows and no-one in th uk seems to know does my clio really have a pcv ? :di know this question has been asks loads of times without reply so ill ask again does anyone know the location of the pcv valve on a 53 plated clio 1.2 16v PLEASE ?
whare is the breather and what does it look like as all i can find is like a plastic pipe with a plug on the end, ive looked and looked and nothing coming of airbox either? this is a bit like the renault secret of where are the wire conectors for rear speakers in a clio as renault dont know that one either. renault said they will call me in 10 mins and that was about 3 ours ago so maybe they still dont know where it is either:dThe PCV valve lives in the breather pipe going between the inlet and the crankcase and is usually well hidden. Disconnect the breather pipe from the inlet and slide a stiff piece of electrical wire gently down and that hopefully shoud give you an idea of its exact location.![]()
Well if that's the case there must be some route between both which will need investigated if there's a problem.just been told this car vents directly from rocker to airfilter no exposed pipes?![]()
from what i was told its actually part of the rocker cover itself but will take pics and put up on here once removed. well done renault for another grand design bit like the black metal boxSo I take it there must be some type of baffle built into the rocker cover.![]()
hi garry, yes it did mate totally cleared it up. what i wrote in my thread is 100% and dont bother wasting your time looking for a pcv valve as there is NOT one. i have old rocker here still which i can send pics of to anyone who wants them showing what a crap idea renault came up with as a breather system none removable none cleanable and a joke. if i can be of further help just ask mate, atvb kriss.Hi Kriss, I along with many others also have the same problem with my 1.2 D4F Clio. Did replacing the rocker cover solve the problem for you?
Yes please.i have old rocker here still which i can send pics of to anyone who wants them showing what a crap idea renault came up with as a breather system none removable none cleanable and a joke.
I think I have this on a Megane K4M engine. May I have a photo too please? Alternatively, what I often do is put them on photo bucket and link to them.i have old rocker here still which i can send pics of to anyone who wants them showing what a crap idea renault came up with as a breather system none removable none cleanable and a joke. if i can be of further help just ask mate, atvb kriss.
do you have pics of this and also part numbers for new rocker cover?from what i was told its actually part of the rocker cover itself but will take pics and put up on here once removed. well done renault for another grand design bit like the black metal box
