Hi, I have a Renault Clio mtv 1.2 petrol 2000 (w reg) and I am having problems with the fuel gauge. I keep getting different readings as I drive. If you just turn the ignition on though I get a solid reading more then what it is saying when the engine is running. What could be the problem? Thanks, Dean.
The fuel gauge alters depending on voltage.
It may be worth checking the battery terminal connections are clean and secure. If no improvement I suggest you have the battery and alternator tested.
No gaurantee that's the problem but these simple checks should be made first.:)
Hi, thanks for the reply, I cleaned and secured the connection, it still gives me off readings, if it isn't the battery or alternator do you know what else it could be?
An auto-spark or a good battery supplier (not one of those fast fit outlets) should be able to do the test while you wait.:)
As Noel has said, the reading is voltage dependant and so it doesn't vary too much due to batter voltage fluctuations the circuit is suppplied by a voltage regulator which keeps the supply voltage constant.
This is normally mounted on the back of the console and usually on a piece of metal to act as a heat sink .
If this has failed then the readings will vary. Its also possible that the fault is with the sender unit mounted on the fuel tank.
