Hi can anyone please help or advise if they have the same smell. When we start the car and after short journeys there is a strong smell of petrol, we've had it checked but can't find any leaks. Our MPG is also low 20's so is this a leak???
Thanks in advance for any help or advise anyone can offer.
Tracey
I had a similar issue just over a year back on my 1999 2.0 petrol.
Warped petrol tank, the seal between the fuel level sender and the tank goes.
Remedy: new tank and sender unit. £500.
The only good news is the fix has lasted 13 months on mine.
:eek:
hi there, hope this helps, the fuel tank sender and pump is placed in top of fuel tank, the supply out pipe to engine is under high pressure when engine is running! this pipe splits at the very top, allowing fuel to escape!! took a while to find as leak was very small to start with!!you will need to drop tank and check very carefully, part is expensive[around£200], so ebay could be cheap source from breaker!! fault is caused by vibration of pipe connected to the outlet of pump!!
good luck,don't smoke when fixing!!
john
We had same problem. It was a crack in the plastic pipe on the fuel pump which sits inside the petrol tank. It broke off in my fingers when I removed it (had to lower fuel tank to do this). When I ordered a replacment (2nd hand) that too had a small crack on it so I covered it with strong glue. Carefully pushed the hose over it and smell stopped! Good luck.
hiya , My 2002 laguna petrol smells fuel when starting and in short journeys, presume it to be same problem,
was it very hard to fix
jeremy
Tracey
Check the fuel injectors i had that i looked at the fuel injectors and fuel rob and found a rubber ring on the first inctor had a flat spot letting the fuel out i turned it around and it was fine after that but still only managed about 25 mpg after that but better than 20 iguess :) just an idea hope it helps.
did you manage to sort your problem i have the same problem now,is there an inspection hole to the top of the tank if not how do i remove the bolts as there just spinning the nuts seem to be turning but there iside chassis any help peeps plz
