1 - 9 of 9 Posts
David don't keep opening a new thread about the same subject please as it will become confusing to keep track of the help you will receive from the members on this forum.. Thanks
So if you have a 1.9DCi Laguna II then you "should" have a PK6, 6 speed gearbox fitted..
Now if you have a 5 speed then it will be a JR5 that takes 2.5 litres of 75w80 oil..
BUT I have never come across a 5 speed 1.9.. Is this vehicle an Import?
What are the first 8 character of your VIN number and I will cross check the build specs..
it is a 5 speed gearbox thats why i keep asking the same question. i live in ireland maybe that is the reason,it is an 04 laguna II 1.9dci the vin number is VF1BGRE0
David, That will explain it.. I will check in the morning and post back tommorrow after work.
1 - 9 of 9 Posts
