Im almost at the point of removing my gearbox but the two star drive bolts at the top of the engine are proving really tight! (Ive sheared 5 drives so far trying to get these out!)
Is there something i'm missing?
Cheers.....
Discussion Starter #2
Ok, box off........eventually.
Is the PK6 box that is fitted to a 1.9dCi the same that is fited to a 2.2. dCi?
Cheers.
L
The code numbers are different, that's all I know, so it could be the ratios are.
A local independent Renault garage should be able to tell you, Renault won't though.
