I have a scenic 2005 1.6 please can anyone advise, august 2010 had one coil pack replaced car fine. feb 2011 similar problem had remaining 3 coils replaced and all sparkplugs at the same time, the next morning to it took 20+ attempts to start the car after parking the car for 2 hours it took 3 attempts to start. each morning it takes a long time to start but not so bad after that. the starter motor is turning over o.k. the garage said it had nothing to do with the coils and plugs and suggested it may be the crankshaft sensor but reading other threads it seems if it was the sensor then the problem would be the same whether the engine was warm or cold .when the car is running it does not stall, could the problem be the plugs they have used. any help would be appreciated
