I have an 02 1.6 Laguna expression that runs ok until I put the climate control on to cold. This makes the revs drop to 600 or less and can stall at a junction etc. Any thoughts on a solution - thanks.
:) hi m8 and welcome to the forums:) the most common fault is a dirty throttle body, clean it with some carb cleaner and this should cure it. this has been covered before and worked ill try and find the post for u bud.:)
Thanks for that Alex - Im just running some jet cleaner through at the moment to see if that will help.
