the door pops when i open it on a lag 2. Ive tried oiling it and tightening the high torque screw that holds the door link on!
Any ideas what else to try?
Hi Cookci - Check if the arm is not seized where it connects to the bracket on the door pillar - if it's OK you may have to strip the door and have a look inside.:)
Not sure on lag's, but on most vehicles I've owned there will be a nylon washer between the arm fixes to the a-frame. I know this can disintegrate over time, and will cause a cracking sound.
Someone on here should be able to tell if there should be one.
If it's a gonna then should only cost around 30 pence for a new washer and 10 minutes of your time to fix.
Hope this helps!
I cant see any washer. Will remove the screw and have a look behind it
thanks for the replies
