Hi all
I've been reading quite a lot of threads on here but none really seem to match my current situation - any advice much appreciated!!
My 2000 W reg Clio 1.4 (sport trim) about 3 months ago started juddering really badly when idle and when stationary at lights etc (whole car shaking).
Changed the plugs which didn't do anything but driving the car is fine - no loss of power or anything like that.
Then a about 2 months ago it started using a lot of oil - but not leaking.
Then about 1 month ago i noticed the heater was not working on cold mornings which in turn led to the car over heating and using a lot of coolant. Took it to a local garage for a quick look and they said thermostat change for the overheating issue and new coil pack for the juddering when starting. I thought as much from reading some threads here so booked a day off work and was pricing up the parts.
But before i could change them the car has started using a LOT of water and noticed coolant splattered all over the engine after most work journeys (40 miles per day). I'm now filling it with water every day.
After reading some threads i'm thinking may be a head gasket issue - ticks some boxes such as watery oil, lots of water use and bubbles in filler tank - BUT - it's driving great (apart from juddering which it has done for months), no loss of power and no smoke or steam from exhaust??
I'm rather reluctant to take back to local garages incase they try and sting me for a new head gasket or other such expensive works.
Anyone any ideas? The car is probably worth less than £1k and has done over 100k miles but apart from that is a good runner and has been well serviced covering mainly motorway miles (40 miles to work and back).
Any help much appreciated!!!!
Thanks in advance
Thanks in advance
