HotShoe WANNABEE..
My PROTON Savvy has the Twingo D4F engine fitted, in Malaysia, as a 'Boxed Part' - from France.
I have no AirCon & the 4grooved PS belt is running simply from the CrankPulley to the Pump... with an Idler/Tensioner wheel, running on the 'flat back' of the belt, directly under the PS pulley.
Does anyone know if this tensioner is on a screw thread (screw it in [to tighten] or out) or is it eccentric (with a big spring inside!) and needs to be turned to release tensioning.
PS Belt is:- 4K 908 8200041851
I'm assuming its just the same as non A/C Twingos....:confused:
I will change the Alt belt :- 3K 751 8200041848... at the same time, as it sits inside the PS belt, on the CrankPulley.
:loser:
knownClone
HotShoe WANNABEE..
Discussion Starter #2
SO.... this is what I'm up against....
And you can see the Alternator Belt is mounted behind the PS Belt, so good plan to do both at the same time :d
:loser:
knownClone
hi
My guess would be to loosen the PS pump to get the belt off, as this idler - looks like idler.
DG
HotShoe WANNABEE..
Many thanks to the Poster [Recycled Scenic] - of the illustrating photos - above.
I have had confirmation (from a PROTON Dealer) that is, indeed, the way to 'lock' this Tensioner.
Any TWINGO (non A/C...) owners will find this useful :cheers:
:loser:
knownClone
