Hi guys,
recently i've been having to top up my levels of power steering fluid every 3-4 weeks. After a wee poke round i found that there is a leak around one of the pipes that comes out of the power steering bottle. Is there anything that i can get to seal the leak or will i just have to get a few new pipes???
Ta
Conor
Leaking steering fluid
Ain't heard of anything that seals leaking steering fluid systems. You'll need a new pipe/s - if it ever runs out of fluid you could be facing a bill of £1000 to fix it - so get it sorted soon.:)
well I sorted my leak out.. cut the pipe under the engine and had a new piece made to the resevior. But watch out if it is the same as the Kangoo, one pipe , the metal pipe , has an "o" ring around the pipe, entering the container. This could be leaking.
