Hi all,
Firstly apologies if this has already been posted. I have read through all FAQ's but haven't come across a problem identical to this.
The problem is with my girlfriends Mk2 Clio (51 plate). I went to lock it via the key fob button this afternoon and after the central locking locked all doors, there was constant high pitched beeping noise coming from the engine area. This noise doesn't appear to go away and as a result we have had to lock the car manually - another point is that when locking the drivers door manually the central locking doesn't appear to work so we have to now lock each door individually. Another point I should mention is that the round circle on the dash flashes red (we don't have the user booklet for the vehicle...its located between 'SERV' and another button that I can't remember) - what does this flashing mean? I have read that the beeping sounds correspond to different faults, but I've not found out what a constant beeping sound means?
I'd be hugely grateful for any advice given.
Thanks in advance.
Thanks in advance.
