Hi!!! Does anyone know of problems with the radio in the Scenic. It will work when the car is cold when its warm or hot it will not work. the display is functional but no sound I have tried everything I can think of to get it to play
Is it showing on the display that it is functioning but no sound?
A shot in the dark could be a thermal cut out on the amplifier when it get's hot, if so it may be a fault in the unit causing overheating.
May need to get a replacement/used unit.
Hey there
Yea its showing its functioning but no sound. If it is what you are suggesting I hope its not expensive to replace.
We've certaintly had many problems with these radios not working in the winter,but this is the first one where a unit won't work due to the temperature being too high.:eek:
O
Hey there
I have one that I took from my 1999, phase 2 before selling it. Its the radiosat 6000 with CD player.
I have the code but no way of checking it still works as the wiring in the newer Scenic is differnet.
Let me know if you are interested.
