My neighbour has just had four new replacement injectors fitted at an independent garage. Apparently the injectors were just changed over and the engine ran OK but the garage stated they don't need programmed.
During similar work in the past I have always had similar injectors programmed in to the ECU. His car has been running for two days now only covering about 10 miles and he is now getting an intermittent fuel injection warning light.
What I need to know is will the ECU throw a fault if the injectors aren't programmed. Otherwise the engine is running perfectly although it hasn't had a long run as yet.
Personally I suspect a dirty EGR valve as the engine was emitting black smoke before the injectors were changed.
Any useful comments would be appreciated.
