how do i check my wheel bearings on my renault scenic 1.6 sport alize ,,,,,,,,, is it a easy job or do i need to take it too a garage,,,,,,,,,,,,,, any advice very much appreciated,,,,,,,,,,,,,,,, thanks
Bill , jack up car one wheel at a time, lighty rest your fingers on the strut spring you will feel grinding from bearing, if not that side do same with other side, to change bearing you will need a press or welder [ weld inside of bearing all way round wait till it cools down bearing will shrink, tap will hammer outer shell falls out ] hope this helps.:d
