G
·The radiator fan has been continually running since I bought the car, Autel FR740 says Temp Sensor open circuit, so I've just replaced it with a new one and fan is still running, don't have the code reader to check again, any ideas what else it could be?
The fan comes on at engine start, and cuts off when the throttle valve housing damper unit activates.
There is no sign of damaged wiring.
Aircon not on (doesn't work)
