1 - 10 of 10 Posts
Probably a daft question, what is the smaller radiator above the larger one in my Renault Trafic DCI 115
Intercooler , two pipes come off this,
One pipe goes to the turbo, the other to the inlet manifold.
It is the width of a normal radiator but only about 10” high. Has a large plastic pipe from the top on one side and small bore rubber pipe on the other top side with what appears to be a drain valve on it.
Just follow the pipes. You'll seen find out what the radiator is for.
1 - 10 of 10 Posts
