I have a Laguna II, I have the radio code but have no display to view the code as it is being inputed is there a simple way that i can input the code for example if I press button 1 would this display a 0 and then i need to press twice for 2 or does it go straight to 1 when you first press it.
O
The code starts at 0000, so if you press the button or turn the wheel or however your car works, it will go to 1.
..or 9 if you go the wrong way.:d
