I own a Renault Clio Campus Mk2. I wondered what is the radio display at the top actually suppose to display? Mine at the moment has just the clock but I have seen elsewhere it is able to display outside temperature and some radio channel functions as well. Does anyone know if this varies with models or if it is something wrong with the radio display itself?
This is the display I have and in the top right I just have the clock.
184134
what it will display all depends on what the head unit itself displays, for instance if you have a head unit like this:-
184143
then the dash top display will not show the station you are listening to, as that will be displayed on the head unit itself,
if you have a head unit that does not have a display screen on it then the radio station you are listening to should be shown on the dash top display along with the "Time"(top right), "Outside Air Temp"(bottom Right), as far as I am aware
