Hi folks,
The radio in my Megane III works OK, but it doesn't illuminate at all. This means when I'm driving in the dark, I can't see where the buttons are.
Has anyone any thoughts on the cause or a fix?
It's the one that looks like this:
189311
Thanks,
Al
If it receive power should light. There is not special signal on it for light up buttons.
Perhaps some component is broken which is giving power for LED's on buttons.
Thanks.
I took it to bits and this is what the control panel looks like.
189341
I think the components with yellow circles on them are LEDs. I couldn't see anything obvious defects anywhere though.
I'm going to put it all back together and use it as it is. I may keep a lookout for a used one that I can swap in. If I do this, will a used one just work with the car's GPS and bluetooth system do you know?
Cheers,
Al
51 plate Laguna 2 1.6
Any problems would probably be on the other side of the board where it picks up power.
