Hi has any one had this problem, When the radio’s on and I then switch on the rear screen
Heater I lose radio reception.
Thanks in advance
Hello & Welcome to the Forums Birdie.
Someone should be able to offer some advice shortly.
Ottoman
Thanks in advance
Not sure exactly why this happens but I do know that the rear screen heating element is used as the radio aerial on some models. There is a aerial amplifier somewhere close by. It could be a fault with this - the 12V for the screen heater may be disrupting the amplifier.
Did this suddenly start happening or after some change or work on the car?
Ian
thanks, no it just happened two months ago no idea why
thourght it was raido but it works fine when rear heaters not on.
Hi i have a problem just like this when i put the rear wiper on i lose reception for a second or two, have check all and cant find anything wrong:confused:
