Recently bought a standard head unit from a 62 plate clio rs to put in my 61 plate rs with nav..
Plugged everything in navs working headunit has power but doesn't show any message to enter a radio code? Can anyone help at all?
from about 2009 renault started to hard code the stereo code into the head units so that when you took the battery off the car you didnt have to keep punching in the code, the UCH (Body Control Module) would check the code stored in its memory against the code that the stereo was providing, if they matched, the stereo would work, as yours wont match, it is a different stereo, you will need someone with a computer thats speak Renault to tell the UCH that the stereo you have now fitted belongs to the car and then if the stereo is compatible it will work.
