HI All
How do I take out my cd/radio player, is there a special key
that fits into the small slots and where can I obtain one?
many thanks
Uri
Hi is it the type with a hole either side at the top and either side at the bottom???? of the radio if yes cut a wire coat hanger in two pieces about 6 inches long and bend into a u shape and then one end of the wire into one hole and the other into the other hole and then do this at the other side and then the radio should pull out
This will only work if it is the type i have described i hope this helps all the best
Banned
With a name like uri couldn't you just think it out? ;)
I use a couple of U bent 2.5 mm welding electrodes with the flux removed. :)
I used 4 wooden kebab sticks (like coctail sticks but thicker!) These are about the same thickness as coat hanger wire that Donald suggested.
Push them about 3 or 4 inches into the 4 holes and the radio will then pull out.
It's not necessary to buy a set of 'pullers'.
Snap. That's exactly what I use, although it's advisable not to grill the steroe afterwards:rofl:
