Hi all, i want to find out if my laguna has rain sensitive wipers and how do i turn them on, or will they switch on automatically.:confused:
Its a 2002 Laguna Initiale.
Many Thanks
An 02 Initiale will have the rain sensing wipers. They're enabled by default (in fact, I don't think you can disable them) and should adjust speed depending on the amount of water that falls on the sensor.
The only thing they don't do is come on automatically if you leave them switched on all the time. If you left your wipers on last time you drove the car, you'll need to turn them off and back on again to get them to work.
Thanks for the info, i have just brought the car but haven't got the users handbook:steam:
What's the deal with the headlamp washers how do i operate them or should they work with the windscreen wash?
Headlamp washers will work whenever you wash the windscreen and the lights are on ( don't think they work if on side lights only - never tried,never use sidelights, always dipped headlights).
