Hi All,
Wonder if you can help, my Laguna sounds a bit rattly when stopped with the engine running, but when you press the accelerator it seems to stop,can you tell me what you think it might be.
Cheers
What Laguna do you have and what engine does it have?:)
RIP 31-12-2008
Hi there, do you have the 8 valve or 16 valve engine, also can you tell if the rattling noise is coming from the top of the engine or the bottom near the sump?
Regards Leroy
It's 16v, but can't tell where in the engine it's coming from, although I have been told that the engine mounting bracket might need replacing, could this be it.
Ta very much.
RIP 31-12-2008
Hi again, that could be the answer but it depends on the type of rattling it is, very difficult without actually hearing the noise. If it's a mechanical clickety click type rattle then it could be a little bit more serious. If a cam follower is worn or a crankshaft shell bearing then the noise will reduce slightly when the engine is revved because firstly the increased engine noise will cover the rattle somewhat and also more oil is being pumped round the engine masking the noise further. If you have a mechanics stethoscope have a listen to bothe the top and bottom end of the engine, if not try a long screwdriver and place the blade on the top and bottom of the engine while it is just on tickover and put your ear to the handle, hopefully it will just be the engine mounting.
Regards Leroy
