1 - 8 of 8 Posts
hi guys i got a reanult laguna on a w plate, today one of the coil packs failed, so i used a coil of my mates laguna to test and find which one had failed, re-placed the coil pack and it made no difference, i could pull the coil pack of the plug with no engine tone change pulling the other 3 off nearly stalled the engine, so i replaced the spark plug but its still the same, like the car is running on 3 coil
Can someone give me an idea as to what the problem is, i checked the wiring the best i can cannot find anything
If you are certain the spark plug is in good nick and is getting a strong spark then the next step is to check the injector is delivering fuel and the cylinder has good compression.
hi m8 cheers for the reply the spark is good and strong, garage time for it, i dont know how to test for compression or how to check the injectors, cheers m8 hopefully it wont be a expensive fix, paid 200 pound last week for exhaust doing
i got it booked in tomorrow for a new injector fitting £56 plus fitting, fingers crossed it sorts it out
1 - 8 of 8 Posts
