Hi all,
Hopefully someone may have had this problem and can help me with a solution.
When indicating my brake light flashes very dimmly and when braking my fog lamp light on my dash lights up. I've tried cleaning all the bulb holder and plugs etc. I also traced 2 earth points in the boot which i cleaned up with emery cloth, But it is still doing it.
I'm really confused is there anymore earth points i could try to clean up.
Help me renault forums you're my only hope..( To be said in a princess leis style )
Thanks All
Check all of your earth connections, and clean them if necessary
sorry but that is the normal thing when this happens
Cheers for the quick reply do you or any one know where the earth ponts are, I found 2 in the boot area coming from the lighting loom and cleaned them is there anymore?
is there any plugs into your light cluster? check the connections for that green coloured stuff that appears and can cause problems! also are all bulbs fitted the correct ones ( earthed through cap body / earted through cap connection) , bulb cap uncleanliness also can cause earth faults!
good luck
