Just bought Clio DCi 2001 do not know anything about fuses but could someone please tell me if the rear screen heater and the horn are on the same fuse both are not working the light does not light up on the dash for the rear screen heater. Thanks:mad:
Hi - Jane rosie - as far as I remember both have separate fuses - have you checked the fuses in the box to see if any are blown:)
Hi Janerosie - did you check both fuse boxes - as far as I remember there is one inside the car and one under the bonnet. If all OK it is orobably a "tracing the fault" job using a test lamp or multimeter. Could also be a faulyt with one of the relays or if your car is fitted with a UCH it could be a fault with it.:)
