This is a really random question- when i use the rear screenwash on my renault clio it washes the front windscreen.but the front screenwash also washes the front screen.and as of yet i cannot get the rear screenwash to work at all.ive checked in the manual and im definitely doing what it specifies to wash the back screen.
my only thought is maybe my clio's not fancy enough to have rear wash/wipe so that facility isn't supposed to work. it's a sept 2002 expression spec if that helps.
anyone know?
Hi yes if you have the rear wiper i would of that you do have that facility to wash with the water jet and if it is the same as my Espace it works from the same motor as the front and from the same water bottle i would first check that the water is not being blocked by a kink in the pipe somewhere or even that the hose that runs fron the front water bottle to the rear wiper has not been disconnected so when you do squirt the water it is just running into the boot panel or else where i hope this helps Donald.
