Hello,
Does anybody know why my rear window heater wont work?
It did previusly work but then stopped.
the button what you switch it on with on the dashboard comes on and light up but the heater doesnt come on in the glass itself.
this can be annoying in winter.
The car is a 1996 Renault Laguna RT 2.0L
Thanks for replying,
i had a look this morning and i cant seem to see any broken filiment strip,But then i soppose it only takes a very little crack to make it not work :confused:
Also the connection at the window looks fully in.
Is there any fuses to the filiment strip that could have gone?
Does it even have fuses?
Thanks :crazy: :d
Hi Chris is right i think if the fuse had gone it would also not light up in the dash but it might have its 12v supply i would check the fuse its worth a try my friend all the best Doanld.
Hello,
I have the same problem. I have checked with a voltmeter and I am not getting 12V at the heater element. The wires disappear into the roof. Does anyone know where to look for them coming out?
