My rear window wiper is very stiff. How do I remove it from the glass as I want to free it of before I burn out the motor. Also the front wiper switch constantly works in the automatic mode. Is there any way I can disable or turn of the auto mode.
I had the same problem, open the rear widow and lift the rubber grommet on the wiper blade spindle a bit with a small screwdriver and clean the rusty crud off the Spindle then spray the spindle bearings with wd40 whilst moving the blade backwards and forward, worked for me, might work for you.
