I need help!
I have a megane 2l coupe y reg
problem is ... my remote control doesn't work.
the battery within it is new and the light within the key lights up when the key is depressed.
ive tried to activate the door lock, but the barrel continues to revolve.
regards
ps . . . I have a worry that someone has tried to force entry as ALL 3 door barrels revolve !
I need help!
regards
if you put in the wrong key the locks just turn around i found this out on my scenic when i had 2 and picked up the wrong keys
Ron
Probably not related, but I always had probs with both beep keys for my Meg Coupe (98 year) had to get right up to the car before the locks would click up or down. Both the rubbish Scenic and the current one are fine, can use the beep button from several yards away. Only difference is that the Meg had a CAT1 as well, whereas neither Scenic had/have one, just central remote locking and immobiliser.
Karen xx
