Hi ,
Just woundering does anyone know do i have to remove the whole panel by the gear stick and hand break to get out the cigarette lighter as it is broken . Have it half out but loose cant seem to get out any further .
I have just been out to my Modus to have a look as I believe it’s in the same place as your Clio, I can only get it out about 2/3 of the way and at an angle I can see the metal casing of the socket itself, it looks like the connectors on the back is what is preventing it from coming through all the way, I have tried twisting it, wiggling it and all sorts but it looks like you have to either lift up sufficiently the plastic centre trim to get you hand underneath to disconnect the wires or remove it completely to make life easier and to not lose the connector
Hi ,
Thanks was thinking the same myself hopeing there was a way to do without removing the casing but here it's never the easy way ***x1f601;. Will wait till new one arrives and then will work on it will post when finished
