1 - 1 of 1 Posts
Hi all,
I have a non charging alternator which is also creating a bad electrical smell. I presume it might be the bushes or the rectifier but need to get it out to look of course.
Before I start removing nuts tomorrow, can anybody tell me how I should go about this? It looks like I need to remove the water pump above before I can get at the alternator, but I'm not convinced it will squeeze past even then.
The belt looks a bit complex - Where do I release the tension to remove it?
Any links to removal instructions would be super appreciated. Having been living in France since the 90s, I miss the old days where I could nip to the library and simply bowwow a Haynes manual in the 80s!
Merci in advance
1 - 1 of 1 Posts
