So I'm looking at removing the exterior trim (plastic lines down side of doors etc) on my Clio dynamique 1.4 to give it a paint change, does anyone know if it can be done with the heat and string approach or does it have clips, thanks
Mark 1, mark 2, mark 3, mark 4,,
Need more info,,,,,:grin2:
Open the door, should see a blanking cover, pull this off, undo the pin, follow trim along remove the side mounted indicator, slide the strip towards the back of the car to remove...
Rear section, it clips off
