:confused: I BOUGHT AN 02 PLATE CLIO 1.5 DCI 65BHP AND I HAVE NOTICED SOMETHING ODD.ON TOP OF THE GEAR BOX THERE IS A MOUNTED BRACKET WHICH SITS TO THE RIGHT OF THE STARTER MOTOR.I HAVE CHECKED MY MANUAL AND IT IS CALLED A THERMO PLUNGER OR HEATER PLUGS.THIS HAS 3 ELECTRICAL WIRES ATTACHED (1 GREEN AND 2 YELLOW) OR SHOULD DO AS MINE CAME OFF IN MY HAND AS THEY WERE SO LOOSE AND I DONT KNOW IN WHAT ORDER THEY GO:eek:. DOES ANYONE KNOW WHAT THIS DOES OR WEATHER THE WIRES NEED TO BE IN A SPECIFIC ORDER ? ? ?
If this item has a coolant hose attached to each end and looks like it feeds the heater matrix then it is an electrical heater to help you get defrosted inside more quickly. AFAIK you can put the wires back on anyway (if they just slide on) as the connectons are to heater plugs.:confused:
