Hello all,
as the title says what is the correct type of coolant to use for the 1.6 8v K7M engine. Not doing a full coolant change, just topping up after replacing a broken thermostat.
Cheers.
Harry.
R
They say you shouldn't mix different types of coolant so if you don't what's in the car it might be better to change all the coolant. I have seen Green, Blue and Red coolant used in the Scenic's I've worked on.
